STM32 debugging issue.
‎2021-12-12 8:04 PM
Earlier I used the STM32CUBEIDE 1.7.0 version it works fine then I update it to 1.8.0 then I faced an issue while debugging it showing an Error in the final launch sequence:
Failed to start GDB server
java.lang.NullPointerException
then I uninstall the 1.8.0 version and reinstall the 1.7.0 version but still, I faced the same error.
So, how can I fix this issue?
Thanks in advance.
STM32CubeIDE
‎2021-12-12 8:24 PM
Which debug probe are you using?
‎2021-12-12 9:09 PM
I am using ST-LINK-V2
‎2021-12-12 11:35 PM
Are you able to program the mcu using different software like STMCubeProgrammer? This will make sure that your probe and mcu are working correctly and non of them is faulty.
‎2021-12-13 6:16 AM
Unfortunately, Eclipse is just not the most robust piece of software. In addition, the debugging tools are often flaky.
If STM32CubeProgrammer connects, the hardware connection is there. Try restarting STM32CubeIDE and/or power cycling the chip.
‎2021-12-13 8:35 PM
Install ST Server again and reboot ...
‎2022-03-10 7:15 PM
Did you find any solution?
I encounter exactly the same problem
I also tried to flash the program using STM link utility and it works fine,
it is just the debugger from 1.7.0 that I cannot use
‎2022-03-10 7:15 PM
I tried this, it doesn't work
‎2022-07-05 3:10 AM
Has anyone found a solution to this? I have the same problem and I have tried all the above mentioned - still not working
IDE Version - 1.7.0
Debugger used is ST-Link V3 mini
‎2022-07-05 5:17 AM
Which STM32 or board do you have?
From my experience, debugger in v 1.7.0 works just fine with ST-Link V3 mini.
Newer versions seem to have some regressions.
If you've copied existing project from other PC or from Linux, try to re-create debug configuration from scratch.
