Remove default source file text
vicvicvar
Hi all,
How can I remove the default text added by the IDE when creating a source file?
For example the one in the attached files?
4 REPLIES 4
Guru
Select what you want to delete and press the delete key?
Indeed a solution, but how could remove or change this default text?
Select <None> as a template and the file will be empty when created.
i Think your are looking for that?
Here you can edit or delete the text.
padawan
