Remove default source file text
‎2024-09-29 7:05 PM
Hi all,
How can I remove the default text added by the IDE when creating a source file?
For example the one in the attached files?
STM32CubeIDE
‎2024-09-29 7:09 PM
Select what you want to delete and press the delete key?
‎2024-09-29 7:36 PM
Indeed a solution, but how could remove or change this default text?
‎2024-09-29 7:41 PM
Select <None> as a template and the file will be empty when created.
‎2024-10-02 12:35 AM
i Think your are looking for that?
Here you can edit or delete the text.
padawan
