Problem with debugging programs on STM32CubeIDE: Error: "Could not determine GDB version"
2023-06-22 5:48 AM
After an update i am not able to debug my program. I have already tried an new installation of the STMCubeIDE 1.12.0 but it still doesn't work. I've already tried to add a local toolchain in the Toolchain Manager, but the error still apears. Does anybody have an idea to solve this problem? :)
2023-06-22 6:47 AM
Hello @Stone1234
First let me thank you for posting.
I suggests you to start by locating the GDB Server
- Ensure that it exists at the customer file system. Example: C:\ST\STM32CubeIDE_1.12.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.10.3-2021.10.win32_1.0.200.202301161003\tools\bin
- Open “cmd” in the folder containing gdb and try to execute arm-none-eabi-gdb.exe --version
It is possible that anti-virus software has either deleted gdb or prevented it from launching. Test 1&2 should be sufficient to tell you if this is true…
I will wait for your feedback.
KR,
Semer.
2023-06-22 11:08 PM
Hello CHERNI,
thank you for the quick reply.
I executed the steps 1 & 2 and got this as the result from cmd:
2023-06-27 6:01 AM
Same here. It works once as soon as I restart STM32CubeIDE and plug the Nucleo board usb cable. Then it stops working. I've just updated the ST-Link firmware on the Nucleo board to latest version.
2023-06-30 1:04 AM
2023-07-05 3:48 AM
@Semer CHERNIAbove, you see the .log file.
2023-08-30 1:07 AM
now I face the same problem with 1.13.1.
for my case, no problem last week, but met error in this week, so I tried clean install with new PC setup yesterday, and also get same error today on new PC.
Attached log file shows following activities..
SESSION 2023-08-29 16:47:02.951
-- inport 2 project from other PC, and do some Debug without problem.
SESSION 2023-08-30 08:29:33.942
-- to make merge from 2 projects, copy one and paste to new-named project, then quit IDE.
SESSION 2023-08-30 08:54:45.200
-- after making merge into new project (using external merge tool), then start IDE and get error when Run/Debug.
further detailed infos, please refer .xlsx attached but sorry that is in Japanese.
still in need help...
