2023-03-15 07:10 AM
I get the following exception when I try to debug en.fp-sns-allmems1:
!ENTRY org.eclipse.core.jobs 4 2 2023-03-15 11:08:42.955
!MESSAGE An internal error occurred during: "Launching SensorTile".
!STACK 0
java.lang.NullPointerException
at com.st.stm32cube.ide.mcu.toolchain.ui.ToolChainHelper.validateDebugLaunch(ToolChainHelper.java:38)
at com.st.stm32cube.ide.mcu.debug.launch.DSFDelegate.preLaunchCheck(DSFDelegate.java:100)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:767)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:716)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1021)
at org.eclipse.debug.internal.ui.DebugUIPlugin$2.run(DebugUIPlugin.java:1224)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
2023-04-08 06:24 AM
Please ignore this question : i think it has something to do with me incorrectly connection the ST Link to the sensortile.
2023-03-15 07:13 AM
!SESSION 2023-03-15 11:04:31.296 -----------------------------------------------
eclipse.buildId=Version 1.12.0
java.version=11.0.17
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=nl_NL
Command-line arguments: -os win32 -ws win32 -arch x86_64
2023-03-16 03:23 AM
Hello @Avan .12
I wonder if this behavior occur when debugging all your projects or just a specific one?
Could you import the project you are debugging into an other clean workspace and tell if the issue keep exiting?
BR,
Semer.
2023-03-16 04:45 AM
1) I updated stm32cubeide to latest 1.12 version
2) created a newIt clean workspace and
3) imported : https://www.st.com/en/embedded-software/fp-sns-allmems1.html
4) i am able to compile it successfully
5) when I hit debug button in stm32cubeide I get this exception immediately
project for sensor tile : https://www.st.com/en/evaluation-tools/steval-stlcs02v1.html
Cheers
2023-04-08 06:24 AM
