After upgrade to CubeProgrammer 2.18.0 cannot run programmer
  • November 27, 2024
  • 790 views
Tried to remove and install previous version
Still have error, linux
Linux namee 6.11.0-107009-tuxedo #9tuxnoble1 SMP PREEMPT_DYNAMIC Fri Nov  8 19:23:20 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
kubuntu 24.04 lts based
2024-11-27 15:03:10,758 JavaFX Application Thread ERROR Unable to locate appender "csvFile" for logger config "com.st.mtt"
Loading PRG Library: /home/username/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/../lib/libCubeProgrammer_API.so
[Analytics] No requests are done with CLI
Could not load Config.fxml
javafx.fxml.LoadException:
file:/home/usernameSTMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32CubeProgrammerLauncher!/fxml/Config.fxml
       at javafx.fxml.FXMLLoader.constructLoadException(FXMLLoader.java:2608)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2586)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2448)
       at javafx.fxml.FXMLLoader.load(FXMLLoader.java:2416)
       at com.st.controllers.MainWindowController.initialize(MainWindowController.java:1304)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2555)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3251)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3212)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3185)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3161)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3141)
       at javafx.fxml.FXMLLoader.load(FXMLLoader.java:3134)
       at com.st.app.Main.openCubeProgrammmerWindow(Main.java:192)
       at com.st.app.Main.start(Main.java:184)
       at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$8(LauncherImpl.java:769)
       at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$7(PlatformImpl.java:326)
       at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
       at java.security.AccessController.doPrivileged(Native Method)
       at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
       at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
       at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
       at com.sun.glass.ui.gtk.GtkApplication.lambda$null$10(GtkApplication.java:245)
       at java.lang.Thread.run(Thread.java:750)
Caused by: java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
       at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1774)
       at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657)
       at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
       at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
       at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
       at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
       at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
       at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
       at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
       at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
       at javafx.event.Event.fireEvent(Event.java:198)
       at javafx.scene.Node.fireEvent(Node.java:8411)
       at javafx.scene.control.Button.fire(Button.java:185)
       at com.st.controllers.ConfigController.refreshAllInterfaces(ConfigController.java:1186)
       at com.st.controllers.ConfigController.initialize(ConfigController.java:484)
       ... 22 more
Caused by: java.lang.reflect.InvocationTargetException
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
       at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
       at java.lang.reflect.Method.invoke(Method.java:498)
       at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)
       at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
       at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)
       at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1769)
       ... 37 more
       at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
       at com.st.controllers.ConfigController.refresh(ConfigController.java:968)
       at com.st.controllers.ConfigController.refreshSTLink(ConfigController.java:996)
       ... 47 more
       ... 59 more
       at com.st.controllers.ConfigController.selectProbe(ConfigController.java:810)
       ... 69 more
       ... 80 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
       at com.st.controllers.ConfigController.selectPort(ConfigController.java:742)
       ... 90 more
Exception in Application start method
       at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:382)
       at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:321)
       at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:893)
Caused by: java.lang.RuntimeException: Exception in Application start method
       at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:823)
       at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$1(LauncherImpl.java:181)
Caused by: java.lang.NullPointerException
       at com.sun.javafx.scene.control.skin.SplitPaneSkin$Content.computeMaxWidth(SplitPaneSkin.java:1165)
       at javafx.scene.layout.Region.maxWidth(Region.java:1451)
       at com.sun.javafx.scene.control.skin.SplitPaneSkin.layoutChildren(SplitPaneSkin.java:705)
       at javafx.scene.control.Control.layoutChildren(Control.java:578)
       at javafx.scene.Parent.layout(Parent.java:1087)
       at javafx.scene.Parent.layout(Parent.java:1093)
       at javafx.scene.Scene.doLayoutPass(Scene.java:552)
       at javafx.scene.Scene.preferredSize(Scene.java:1649)
       at javafx.scene.Scene.impl_preferredSize(Scene.java:1723)
       at javafx.stage.Window$9.invalidated(Window.java:889)
       at javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:109)
       at javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:144)
       at javafx.stage.Window.setShowing(Window.java:965)
       at javafx.stage.Window.show(Window.java:980)
       at javafx.stage.Stage.show(Stage.java:263)
       at com.st.app.Main.openCubeProgrammmerWindow(Main.java:524)
       ... 1 more
Exception running application com.st.app.Main
Best answer by Aziz BRIGUI
Hello @AndriiGalinovskyi
We apologize for the inconvenience, but kubuntu doesn't figure in the list of supported OS mentioned in UM2237 page 12. I suggest if you're using STM32CubeProgrammer to switch to any of the linux distributions listed in the user manual.
I just tried doing the update from v2.17 to v2.18 in ubuntu 24.04.1 and it works just fine.
Aziz
Aziz BRIGUI
Aziz BRIGUIBest answer
Aziz
The problem appeared after new system updates and disappeared the next day after the next updates. I lost a day trying to solve it, but now everything works again. Thanks
