nucleo-F756ZG with Qorvo DWM3000
DimitriosG
I have connected the nucleo f756zg board with the qorvo dwm3000. I found the inc and src files for the dwm3000 but the drivers for the dwm3000 are available for the m33 and m4 families.
Is it someone who used an M7-Cortex mcu and have the driver for the dwm3000? Or, is there any other way to go?
Thank you in advance,
Dim
If you've got the source files, port it.  Work with the vendor their FAE's or consultants.
CM4 code should run on a CM7
Related to these?
https://community.st.com/t5/stm32-mcus-embedded-software/dw3300q-stm32-sdk/td-p/676724
https://community.st.com/t5/stm32-mcus-wireless/dwm3000-problems-with-reception-using-stm32wb55-and-dwm3000-api/td-p/58720
Pavel A.
Evangelist III
Here you can find help with adaptation or development of the driver.
