Linux installation error
‎2024-09-24 8:01 AM - last edited on ‎2024-09-24 8:21 AM by Andrew Neil
d64.deb'
Note, selecting 'st-stlink-udev-rules' instead of './st-stlink-udev-rules-1.0.3-2-linux-all.deb'
Note, selecting 'st-stm32cubeide-1.15.1' instead of './st-stm32cubeide-1.15.1-21094-20240412-1041_amd64.deb'
Note, selecting 'segger-jlink-udev-rules' instead of './segger-jlink-udev-rules-7.94h-linux-all.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
st-stm32cubeide-1.15.1 : Depends: libncurses5 but it is not installable
Depends: libpython2.7 but it is not installable
Depends: libwebkit2gtk-4.0-37 but it is not installable
E: Unable to correct problems, you have held broken packages.
Which STM32IDE we should download to fix this error
‎2024-09-24 8:22 AM
What version did you download?
What Linux version do you have?
‎2024-09-24 9:47 AM
linux ubuntu 24LTS
i had downloaded 1.15 stm32idecube linux installer
‎2024-09-24 9:49 AM - last edited on ‎2024-09-24 9:56 AM by Andrew Neil
You posted this as a reply to the Posting Tips - it's not appropriate there, so merged here.
d64.deb'
my os is ubuntu 24lts
stm32cube ide linux installer
‎2024-09-24 9:49 AM
Current version is 1.16.1:
https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-1-16-1-released/td-p/721704
‎2024-09-24 9:51 AM
yeah i had tried that as well but was showing the same error
‎2024-09-24 9:53 AM
@shri1 wrote:i had downloaded 1.15 stm32idecube linux installer
Which one?
There are three:
https://www.st.com/en/development-tools/stm32cubeide.html#get-software
‎2024-09-24 9:55 AM
generic linux installer second one
‎2024-09-24 9:59 AM
stm32cubeide_1.15.1_21094_2012_1041_amd64.deb_bundl
‎2024-09-24 2:18 PM
- Please post an update with details once you've solved your issue. Your experience may help others.
