lcd.c file not found
‎2024-07-05 04:00 AM
so im trying to run a project example from the stm32h747i disc0 repository from github. specifcally the DCMI project i want to try the camera using snapshot mode or capture mode .when i pen the project and try to build it i gave this error saying that the lcd.c file is not found in project files(Description Resource Path Location Type
make: *** No rule to make target 'C:/Users/gouiaa/Downloads/en.stm32cubeh7-v1-11-2/STM32Cube_FW_H7_V1.11.0/Utilities/lcd/stm32_lcd.c', needed by 'Utilities/stm32_lcd.o'. Stop)
and the file really doesnt exist in this path when i cheked th project folders. any help please?
‎2024-07-17 01:22 AM
Hello @yessine ,
I think you facing another issue which is different from the initial one. For more visibility it recommended to create a specific thread for this new issue.
-->the snapshot mode worked perfectly but the capture mode didnt .
What do you mean by capture mode didn't work. Do you get a noisy screen with DCMI_CaptureMode example?
To make work the DCMI_CaptureMode example with MB1166 Rev-09, it is recommended to use the latest STM32Cube_FW_H7_V1.11.2 version and change the code lines in stm32h747i_discovery_conf.h file under STM32Cube_FW_H7_V1.11.2\Projects\STM32H747I-DISCO\Examples\DCMI\DCMI_CaptureMode\Common\Inc as mentioned in readme
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
‎2024-07-08 04:39 AM
Hello @yessine ,
I checked the DCMI project available in the STM32Cube_FW_H7_V1.11.x and it works properly.
Please check the include path and make sure that it is included in your source folders:
Project properties -> C/C++ General -> Paths and Symbols -> Source Location.
Imen
‎2024-07-16 01:58 AM - edited ‎2024-07-16 02:00 AM
update :
i managed to run the project . i used the folder that was downlaoded automatically when i selected the board the first time in MX. now i have an other problem. the snapshot mode worked perfectly but the capture mode didnt . when i checked the readme file i found this configuration that i need to do since im using a rev09 camera but i couldn't manage to do it . so is there any guide to help me so this adaptation. in which file i can find these lines of code...
Hello @yessine ,
Thank you.
Kaouthar
‎2024-07-17 07:19 AM
im glad to say that everything work . problem is solved . capture mode and snapshot and people counting feom fp ai vision folder
for fp vision folder i followed some steps from this link https://wiki.st.com/stm32mcu/wiki/AI:How_to_perform_people_counting_using_FP-AI-VISION1_and_STM32H747XI
it was jut a problem of sime files that i need to paste from 11.2 folder
and for capture mode i just needed to change a line in some config.h file (change nt**** to OU from 1U and and om**** from 1U to OU)
