2023-09-14 01:28 AM
is there a way to configure the .launch file to download automatically the .elf file corresponding to the active build configuration (es. Debug or Release)?
Or should I create two .launch files, one for Debug and on for Release?
I tried to play with some of the build setting in the window below, without success (es. the Release .efw file is still downloaded, even if I have selected as active configuration, the Debug one).
Thank you,
Carlo
