I have installed STM32CubeIde, however beyond the flash screen the software is not loading
‎2023-01-16 4:18 AM
‎2023-01-16 4:23 AM
Hi @SatishB​ ,
Description of your issue is far too short.
What do you call "flash screen" ?
Which firmware ?
Please add further details.
Olivier
‎2023-01-16 4:33 AM
I am using version STM32CubeIDE 1.11.0. I have attached the screen for your reference.
Thanks Oliver for your reply.
‎2023-01-16 4:36 AM
‎2023-01-16 6:59 AM
Hi @SatishB​ ,
Ok logs state about a Java exception. I will try to help your post to reach a CubeIDE expert.
Olivier
‎2023-01-17 2:14 AM
‎2023-01-17 4:20 AM
Hi Wijeden,
I am pasting the contents of log file below
!SESSION 2023-01-17 17:16:52.366 -----------------------------------------------
eclipse.buildId=Version 1.11.0
java.version=11.0.16
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2023-01-17 17:18:06.843
!MESSAGE CubeMX plugin appears to be active, Log4j initialization might be too late.
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2023-01-17 17:18:07.304
!MESSAGE Log4j initialized with config file C:\Users\Satish\STM32CubeIDE\workspace_1.11.0\.metadata\.log4j.xml
Hope this info is useful to you.
Also I had given a log file in my earlier mail. (hs_err_pid_5892). You can also go through it.
‎2023-01-18 2:02 AM
Hello @SatishB,
I wonder you to check the following stuffs :
- My gut feeling is that installation is broken or that your environment prevents it from executing properly (installation failure or firewall / anti-virus)…
- Is that the full .log file or just pasting a part of it ? (it seems that the copy paste .log file is useless :pensive_face: ) --> if it is the case please share the whole file .
- Maybe you should use the command line to launch the Cube IDE
I wait your response :).
Best regards,
Wijeden,
‎2023-01-18 4:04 AM
Hi Wijeden,
- I have given you the full log file.
- I have disabled antivirus while installation
- What is the command line command to launch
‎2023-01-18 5:04 AM
Hi again SatishB,
More details :
Running Cube IDE in console mode depends on the OS (the paths are just typical places for the binary):
- Linux: /opt/st/stm32cubeide_1.11.0/stm32cubeide
- Mac: /Applications/STM32CubeIDE.app/Contents/MacOS/STM32CubeIDE
- Windows: c:\ST\STM32CubeIDE_1.11.0\STM32CubeIDE\stm32cubeidec.exe
Please verify which OS you are working on ?
Best regards,
Wijeden,
