How undo "exclude from build" for a file?
RPatt.11
In STM32CubeIDE 1.12.1 I right-clicked on a .c file in the Project Explorer view and excluded it from build.  Now I want to include it back in my build.  How do I do that from the IDE?
thanks,
russ
JP_ama
Go to the "Exclude from build" dialog again, uncheck the boxes for Debug and Release and hit OK to include the file back into the build.
4 REPLIES 4
JP_ama
RPatt.11
The file I excluded disappeared from the Project Explorer window.  When I excluded it I right-clicked on it then Resource Configurations->Exclude from build.    How do I get back to the "Exclude from build" window for a file that is missing from the Project Explorer window?
thank you
RPatt.11
Wow, never mind.  I see it greyed out at the bottom of the Project Explorer window.  Sorry I wasted your time.
RajPadgaonkar
Answer to this question totally depends on what kind of file you want to undo " exclude the build ".
1) for header files (xxx.h) --> go to header file, left-click and select properties (Alt + enter), navigate to resource section, select  C/C++ build tab. click on configuration tab and select [all configurations]. Uncheck the box Exclude resource from build. Apply and Close.
2) for source files (xxx.c)  --> left click on .c file and click Resource Configuration and select Reset to Default.
I hope that helps for you,
