2019-08-07 05:28 AM
Hi all,
I am using STM32Cube IDE (Eclipse based) and I am trying configure the IDE to reflash the uC using the Run option rather than Debug option, without success.
I always used OpenOCD from shell under Linux for this purpose.
How can I setup the STLink for Run configuration in STM32Cube IDE ?
Is there any small tutorial / user guide / AN available ?
Thanks in advance.
Simon
2019-08-07 11:17 AM
in the release notes https://www.st.com/content/ccc/resource/technical/document/release_note/group0/9a/72/48/16/ec/bd/44/5a/DM00603738/files/DM00603738.pdf/jcr:content/translations/en.DM00603738.pdf is stated:
The [Run] button is not yet implemented and is therefore hidden from the toolbar menu and Run menu.
so unfortunately this function is not yet implemented.
Best regards
fabi
2019-08-08 01:39 AM
Oh, wow...
Thanks.
s.
2019-08-09 02:33 AM
You could use the argument "quit" in the Debug Script to achieve a similar result, a sort of workaround.
In the Startup tab there is a box called "Run commands". Having the argument "quit" will immediately terminate the debug session.
2019-08-09 02:47 AM
@Markus GIRDLAND i thought that there is still a difference between building with or without debug symbols, or am I mistaken at that point?
