How to tell CubeIDE to compile specific *.c files with C++ compiler ?
ferro
Senior III
Changing suffix from *.c to *.cpp is not an option.
[edit] Changing the suffix from *.c to *.cpp is the least preferred option.
Thank you
22 REPLIES 22
Okay, you did not. Thanks.
And what happened? Can you show build log?
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
