how to open new project for F103 with SPLibrary
mehmet.karakaya
hello forum ,
I am trying to open new project for F103C8 with SPL ( starting with empty project )
I squeezed errors down as to the following picture
how can I go further ? thank you
6 REPLIES 6
mehmet.karakaya
nobody has an answer ?
Cartu38 OpenDev
Lead II
Any chance to share your ptoject (zip file) ? ST is no more doing promotion of SPL since a while not sure you'll get so much support ...
mehmet.karakaya
zip file attached - thank you
Ozone
Lead
I suggest another route.
Get the SPL for the F10x MCUs or for the VL-Discovery (if you haven't already), and pick one of the provided example projects.
Get it to compile/build, and then replace the main application sources with your own.
I used to do it that way.
hello thank you
I did just like what you suggested - I clicked the project file(GPIO_Toggle_Project of VLDiscovery board) and CubeIDE opened the project
however when I tried to build it gives following error - any advice thanks
Definitively not SPL expert.
Your compilation issue is related to following lines. Commenting them is solving trouble.
0693W000005Ac5FQAS.pngBut such code may be useful ... so maybe so help here: http://www.cesareriva.com/fix-registers-may-not-be-the-same-error/
SPL proposal is really deprecated one ... no more support on.
Please tag such post as answered if ok to you it will help community
