How to open an existing project
‎2022-06-18 04:15 PM
I would like to open an existing project :
But when I select .'project' I have this picture and I can't see the code :
Do you know how to do ?
Thank you for your helps
- Labels:
STM32CubeIDE
‎2022-06-18 06:29 PM
- Start CubeIDE. If it prompts for workspace, point it to some workspace or create new
- File -> Import-> Existing projects into workspace
or File-> Open projects from file system
‎2022-06-19 02:29 AM
After Start CubeIDE\point it to some workspace\ File ->Import -> Existing projects into workspace I have this picture : It's already exist in the workspace but I don't see anywhere. I have always the same windows as my previous message.
‎2022-06-19 02:52 AM
After activating the tab
Now I can see the file
But How I can close the 'SGTL_5000' and 'SAI_AudioPlay' because this is not the project that I would like to open. I only work with the project 'STM32_DSP_IIR-master'. Unless it's not important and I can leave it that way ?
‎2022-06-19 02:58 AM
I think it's with this option : Now it's look like correct after me :
‎2022-06-19 06:14 AM
Right click on your project in the left pane -> Close unrelated projects
‎2022-06-20 07:10 AM
Hi Pavel A,
Now It's good.
Thank you
