How to erase flash before programming with STM32CubeIDE [Solved]
SThre
Is there someway to do this with stm32cubeide?
For my specific use case I am storing configuration data on last page of flash (currently working on figuring out how to erase it so i can rewrite it in software), but I would also like to be able to configure it by reprogramming it. I can check that the page is empty and write settings to it, but I haven't found any way to erase it with stm32cubeide, I need to open the st link utility in order to erase the flash as far as I can tell.
11 REPLIES 11
Yes it looks that way.
I guess this is simply not implemented in the gdb server. But a suggestion would be to have "monitor flash bank1_erase" and "monitor flash bank2_erase"
