2024-01-08 05:00 AM
I'm trying to maintain a directory structure in my CubeIDE project that contains an import of a third party repository, however the directory is erased when I regenerate the drivers after saving changes to the .ioc file. I'm using Azure RTOS which conveniently creates a 'Middlewares' directory inside which I added a new directory called 'Third_Party'. Sometimes the ioc build leaves it alone, but most times it does not. Is there a way to prevent erasure of the directory?
2024-01-08 06:04 AM
Put the folder in the top-level directory rather than under Middlewares.
2024-01-08 06:04 AM
