2020-03-07 06:35 AM
2020-06-22 03:04 AM
I had a similar problem with my Nucleo_L476RG, the SWV data Trace Timeline Graph was not showing anything.
I just changed the "Core Clock "of the "Serial Wire Viewer" (Debug configuration window) to the exact HCLK frequency (which is 80MHz in y case). You can find your HCLK frequency in the STM32CubeMx (Clock configuration) if you use it.
I hope this will help you.
2020-07-11 07:48 AM
Excuse me,would you please look at my similar question? Thank you very much, URL:https://community.st.com/s/question/0D53W00000CRovkSAD
