Hi! I am new to all this stuff. While transfering Keil project to Cube IDE I'm facing many issues, is there a proper step by step tutorial or help on how to transfer kei project to cubeIDE? Also help me with following errors
AKhan.6
Errors
  • fatal error: rt_sys.h: No such file or directory
 #include <rt_sys.h>
I have this fuction in somefile
 __asm void MSR_MSP(u32 addr)
 MSR MSP, r0 //set Main Stack value
 BX r14
  • error: expected '(' before 'void'
  • error: expected identifier or '(' before string constant
  volatile("MSR MSP, r0")
4 REPLIES 4
Guru
Might be easier to generate a project in CubeIDE and then transfer your user code over. Kiel uses a different compiler, so a lot of system files are not going to transfer over well.
You don't have rt_sys.h and probably don't need it. If you have semi-hosting for putchar/fputc then you're going to have to replace that plumbing with GNU/GCC equivalent code.
You'll also need to move to CMSIS supported __set_MSP() from Drivers\CMSIS\Include\cmsis_gcc.h
prain
Senior III
cubeide uses GCC. GCC have different naming conventions ​than ARMCC used by keil. for example writing assembly functions is different. Read gcc-arm-non-eabi documentation for more details.
S.Ma
Principal
Create a cubeIDE project, set the mcu and packages and the peripheral and clocks settting and from there, import your source files incrementally.
Eclipse fans will like CubeIDE, Keil or IAR...
