2019-10-09 11:11 AM
Hi, Through STM32CubeIDE I'm acquiring analogue signal, using STM32 F3 DISCOVERY.
The converted values are saved in a register, then I'd like to be able to read them on the screen through TERA TERM, but I can't activate the serial port. Can you tell me what the problem is please?
2019-10-09 02:13 PM
Your question basically indicates you failed, but lacks any details as to why.
What pins and USART did you try to bring up?
2019-10-10 12:38 AM
I 'd like to know if there's a way to create a file.txt, where it can save the values acquiring, without using USART
