Hello all, CubeIDE project panel icons have changed. How to get back to original state? I see question marks on some, in some other instances '>' precedes the file name, some show a location name although the folder is in the workspace.
Parmin Nayani
Semer CHERNI
Hello @Parmin Nayani​
Could you please provide more details about the tool behavior
  • Screenshots for the changed icons
  • did you try something that could be the cause of this behavior
I can suggest that you create another workspace where you try to import the same project and verify if the issue still exsit.
Kind regards,
Semer.
Parmin Nayani
Hi Semer CHERNI,
Thank you for your reply. Here is a picture showing some projects. As you suggested I imported a project into another workspace and here it opened properly. However, the workspace I normally use has many projects and it is here the problem cropped up. Hope you will find the issue. Thank you very much once again.
Best regards
Partha
