Hello all,
CubeIDE project panel icons have changed. How to get back to original state? I see question marks on some, in some other instances '>' precedes the file name, some show a location name although the folder is in the workspace.
2022-11-09 3:55 AM
2022-11-10 1:54 AM
Hello @Parmin Nayani
First let me thank you for posting.
Could you please provide more details about the tool behavior
- Screenshots for the changed icons
- did you try something that could be the cause of this behavior
I can suggest that you create another workspace where you try to import the same project and verify if the issue still exsit.
Kind regards,
Semer.
2022-11-10 4:30 AM
Hi Semer CHERNI,
Thank you for your reply. Here is a picture showing some projects. As you suggested I imported a project into another workspace and here it opened properly. However, the workspace I normally use has many projects and it is here the problem cropped up. Hope you will find the issue. Thank you very much once again.
Best regards
Partha
