2023-06-02 06:35 PM
Hi.
I am working with STM32CubeIDE and using the using STM32F469I-DIDCO. I created a standalone project and enabled semihosting: I can properly open and write into a file with fprintf function.
I then switched to my current project (in C++) and enabled semihosting there. I can compile and link properly, I can see that I can open and close a file, but nothing is written inside.
Can you please help? I searched online but can't find a way to make it working, and not sure what are the differences between the two projects (except one in compiled with gcc and the other g++) that would explain why it does not print.
2023-06-03 02:33 PM
missing fflush ?
2023-06-05 11:52 AM
Hi @Remo Borsella
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
