2023-08-29 12:13 AM
Hello, I have a Nucleo H745ZI-Q board in this am working Ethernet fallowed some examples when doing ping test response is Destination host unreachable(am using CM7 and done memory configuration also).
2023-08-29 02:57 AM
Hello again @sa V.1,
You can find all H7-related examples here: https://github.com/STMicroelectronics/STM32CubeH7
For an Ethernet / LwIP example check this link: https://github.com/stm32-hotspot/STM32H7-LwIP-Examples
This thread could also be helpful!
2023-08-29 01:53 AM
Hello @sa V.1,
It is recommended to follow the same configuration as in the examples provided in the STM32CubeH7 firmware package
Also, check this FAQ : https://community.st.com/s/article/FAQ-Ethernet-not-working-on-STM32H7x3
Hope that helps!
2023-08-29 02:44 AM
Am using STM32Cube IDE v1.10.0 Where could i findout the exmples ? Can you specify the path to reachout the examples ....
2023-08-29 02:57 AM
2023-09-04 10:28 PM
Ethernet configuration and ping test done . Ping Test successfully ping's .Next i want send data from PC to Board or receive data How and where should i process(in code - function )the data and how should i achive . checking ping test in command prompt .
2023-09-05 02:06 AM
Hello @sa V.1
Happy for your progress!
Could you please post another question for the other query so that it's more visible!
