error message from debugger back end: error finishing flash operation;
‎2019-11-03 6:38 AM
i'm using stm32f407 discovery board, and mac as host and i'm getting the above error while debugging. Please someone help me to resolve this issue
STM32CubeIDE
STM32F4 Series
‎2019-11-03 1:47 PM
You might check your option bytes are sensible for debugging with STM32CubeProgrammer. E.g. RDP is off, WRP and PCROP over the sectors you're loading are off, hardware WDG is off.
‎2020-08-04 12:16 AM
You have to install STM32 ST-Link Utility and erase with it the whole flash memory. After that, update the firmware on the board again.
For me this solved the problem.
‎2021-01-13 12:42 AM
Actually there is a simple way to solve this problem:
