Error from debugger back end
‎2023-01-28 03:08 AM
While programming an stm32f446re in stm32cubeide 1.10, UART protocol caused me trouble as this errors appeared:
1) Failed to execute MI command:
-var-create - * UART
Error message from debugger back end:
-var-create: unable to create variable object
2) Unable to create variable object
3) Failed to execute MI command:
-data-evaluate-expression UART
No symbol "UART" in current context.
4) Failed to execute MI command:
Does anyone knows how to solve it?
STM32CubeIDE
STM32F4 Series
UART-USART
‎2023-01-30 01:27 AM
Hello @jreis.1​
Could you share the debug configuration as well as the complete debug log to give a clearer view about the issue.
Thanks,
Semer.
‎2023-01-31 02:46 PM
Hi! Here it is the debug configuration. How can i get the debug log? Thanks in advance!
‎2023-02-01 07:18 AM
Hello @jreis.1​
My bad I should have put a description on how to get the debug log.
Under the debug configuration -> Debugger check the log to file option as shown in the screenshots:
Kind regards,
Semer.
‎2023-02-01 09:24 AM
Hi, thanks for the help! right now I don't have the Nucleo with me, can I send the debug log here on Tuesday?
João
‎2023-02-07 05:46 PM
Hi, today i changed my nucleo board and the error dissapeard, altough i continue not reciveing uart messages... at least the it is not activating.
Here it is the debug log.
