"project is part of hierarchical structure. Would you like to import entire project structure?"
RongShengWang
After CubeMX auto-code generation, CubeIDE shows message: " project XXX is part of hierarchical structure. Would you like to import entire project structure? Yes/NO?  "
if I choose "Yes", a sub-directory will be created inside my project which is not desirable. How to fix it?
Thanks,
Peter
Souhaib MAZHOUD
Hello @RongShengWang
Ensure that the project is not generated inside another project and try to change the path of your project to another directory.
BR,
Souhaib
