2021-03-26 06:12 AM
After installation of CubeIDE 1.6.0 Code generation freezes and never unlocks.
Project was done on previous version of CubeIDE with firmware version 1.24.1. When I try to migrate it doesn't change anything. But if I use the same IOC for generation of new project it doesn't hangup.
2021-03-26 06:50 AM
could you share <workspace>/.metadata/.ide.log file and possibly .ioc file ?
2021-03-26 07:34 AM
Regrading IOC I would need to obfuscate it a little bit. log looks like this:
It looks like it hangs up on access to: http://sw-center.st.com:80
2021-03-26 15:20:20,386 [INFO] ApiDbMcu:458 - Load IP Config File for PDM2PCM
2021-03-26 15:20:20,417 [WARN] FreeRTOS:989 - Null or empty value: should not occur! (nothing added to the table)
2021-03-26 15:20:20,502 [INFO] LogOutputStream:76 - [STDOUT_REDIRECT] toolchainItems.length=====1
2021-03-26 15:20:20,602 [INFO] RtosManager:597 - Active RTOS found at IOC load: FREERTOS [Cortex-M4NS]
2021-03-26 15:20:20,602 [INFO] OpenFileManager:323 - Restore cursor
2021-03-26 15:20:21,804 [ERROR] LogOutputStream:74 - [STDERR_REDIRECT] Managed Build system manifest file error: Could not load icon "icons/chip.png".
2021-03-26 15:20:44,093 [INFO] RetryExec:97 - I/O exception (org.apache.http.NoHttpResponseException) caught when processing request to {}->http://sw-center.st.com:80: The target server failed to respond
2021-03-26 15:20:44,093 [INFO] RetryExec:113 - Retrying request to {}->http://sw-center.st.com:80
2021-03-26 07:46 AM
Initiating a new session is Help > Check for Updates able to complete ?
If not fix your remote access. Doing migration process some db download is required. If not able may explain ...
2021-03-26 08:32 AM
"Help > Check for Updates" is working correctly.
2021-03-26 08:53 AM
Are you able to get following green check ?
2021-03-26 09:14 AM
Yes
2021-03-26 09:18 AM
now log during generation hangs in different place:
2021-03-26 17:15:19,651 [INFO] ApiDbMcu:458 - Load IP Config File for FREERTOS
2021-03-26 17:15:19,713 [INFO] ApiDbMcu:458 - Load IP Config File for LWIP
2021-03-26 17:15:19,713 [WARN] BspModel:441 - BSP dependency skipped because of component: name='LAN8742', api='BSP_COMPONENT_DRIVER'
2021-03-26 17:15:19,744 [INFO] IPUIPlugin:64 - create IPUIPlugin
2021-03-26 17:15:19,751 [INFO] IPUIPlugin:64 - create IPUIPlugin
2021-03-26 17:15:19,766 [INFO] IPUIPlugin:64 - create IPUIPlugin
2021-03-26 17:15:19,767 [INFO] IPUIPlugin:64 - create IPUIPlugin
2021-03-26 17:15:19,768 [INFO] ApiDbMcu:458 - Load IP Config File for PDM2PCM
2021-03-26 17:15:19,783 [WARN] FreeRTOS:989 - Null or empty value: should not occur! (nothing added to the table)
2021-03-26 17:15:19,866 [INFO] LogOutputStream:76 - [STDOUT_REDIRECT] toolchainItems.length=====1
2021-03-26 17:15:19,967 [INFO] RtosManager:597 - Active RTOS found at IOC load: FREERTOS [Cortex-M4NS]
2021-03-26 17:15:19,967 [INFO] OpenFileManager:323 - Restore cursor
2021-04-09 12:12 AM
It looks, that with the newest update (Version: 1.6.1 Build: 9958_20210326_1446 (UTC)) of CubeIDE problem disappeared.
2021-04-09 03:25 AM
Thanks for sharing. Thinking on my side local issue. Updating your IDE has just helped to perform some local state refresh.
Hopefully working now for you !
