CUBE IDE handle_vCont_t,
BengofEtech
i got with the CUBE IDE the following problem, at some random point in the program, the Debugger halts and throws following error:
handle_vCont_t, Thread already stopped
It occurs several Times a weak and i didnt found a solution to this
PPate.3
I am also facing the same issue and I resolved it, can you please let me know the application you develop so that I can help to resolve this issue,
In my case, I was using a GPIO specific pin but there is some pin that is used for some alternate functionality so that information we can get from the manual.
So please check the GPIO pin used in your project if any
Hope it helps you!
