Change static library project target device in STM32CubeIDE
RMais
I'm creating a static library project that is portable across many mcu because it is target indipendent code. The problem is that once I created the project, it seems impossible to change che mcu setting inside Project Properties > C/C++ Build > Settings > Tool Settings panel, as shown below:
The box is grey and the compilation flag -mcpu is fixed and cannot be changed.
I wanted to make different build configurations with different target devices.
Is there a way to do that?
Thank you for your time.
0 REPLIES 0
