Cannot Set Ram2's Load address
zdong.1
Mcu:stm32L471RET6
IDE:stm32cubeide 1.1.0
How can i set the ram2's load address like as ram?
4 REPLIES 4
berendi
Principal
The contents of the .bss sections are initialized to 0 by the runtime startup code, they are not loaded from anywhere.
zdong.1
When build the project, the ide generate the bin file and include large mount of zero at the end of the file. I try to set the ram2's load address to solve this problem.Is there any other way?
When build the project, the ide generate the bin file and include large mount of zero at the end of the file. I try to set the ram2's load address to solve this problem.Isthere any other way?
berendi
Principal
Check the map file, what is actally loaded at at those addresses filled with zeroes.
What else did you change in the linker file?
