Cannot manage software packs nor generate code under Ubuntu
I have installed STM32CubeIDE v1.15.1 on Ubuntu 22.04 (from debian bundle archive 21094_20240412_1041).
First, the Linux terminal shows a periodic error, not correlated to any user action, and which I suppose is not related with the other problems (see points 1 and 2 below) :
Jun 11, 2024 1:21:25 PM java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
WARNING: Could not lock System prefs. Unix error code 0.
Jun 11, 2024 1:21:25 PM java.util.prefs.FileSystemPreferences syncWorld
WARNING: Couldn't flush system prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
1) I created a project and then tried to launch the "Manage software packs" utility by clicking in the "Software Packs" menu or with shortcut "ALT+U" but nothing happens (no window displayed), no error is displayed in the terminal.
2) I tried to generate the code of the project with "Project-Generate Code" or "ALT-K", a pop-up is briefly displayed but no code is generated and the following errors are displayed in the terminal :
java.lang.NullPointerException: Cannot invoke "com.teamdev.jxbrowser.browser.Browser.mainFrame()" because "this.browser" is null
at com.st.microxplorer.plugins.userauth.WebApp.isAuthenticated(WebApp.java:638)
at com.st.microxplorer.plugins.userauth.UserAuth.handleAuthentication(UserAuth.java:477)
at com.st.microxplorer.plugins.userauth.UserAuth.getSpecificTask(UserAuth.java:269)
at com.st.microxplorer.plugins.projectmanager.engine.MainProjectManager$3.onCommandEntered(MainProjectManager.java:232)
at com.st.components.util.CommandLineManager.onCommandEntered(CommandLineManager.java:180)
at com.st.components.util.CommandLineManager.runCommand(CommandLineManager.java:198)
at com.st.components.util.CommandLineManager.runCommand(CommandLineManager.java:214)
at com.st.components.util.CommandLineManager.runCommand(CommandLineManager.java:381)
at com.st.stm32cube.common.mx.editor.CubeMxEditor$24.run(CubeMxEditor.java:2431)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
I tried to do the same with IDE launched under "root" user but I got the same results
Anyone knows what's going on, please ?
