Can't install MCU packages
AVenc.16
After choosing Help→Manage Embedded Software Packages and selecting from the list F3 package I get "Error downloading the file" (more details in attached picture). Tried downloading the file manually and installing using local copy, but also get an unzip error (see second picture).
Is this a know issue? Or am I doing something wrong?
1 REPLY 1
Check you have adequate hard drive space.
Use "Test" on .ZIP archive using tools like WinRar, make sure it is intact.
Check if AV software is running interference on normal usage / extraction of the archive, might be .EXE inside.
Compute MD5/SHA hash of file for comparison with known working packages.
