CAN id incorrect
‎2024-09-26 4:33 AM
I have a STM32G474 mcu that i am learning to program. I have the CANBUS tx on PA12 working by loopback mode. I have connected my logic analyzer and i receive the data correctly.
There is only one thing wrong: The ID has bit1 that keeps being set to 1. So if i would give the adress
0x200 (0b0010 0000 0000) it outputs 0b0110 0000 0000)
0x100 (0b0001 0000 0000) it outputs 0b0101 0000 0000)
Anyone with idea's how this is possible?
Thanks!
‎2024-09-30 2:21 AM
I have done both a loopback program and a normal mode program. Both show the same ID fault. I have created a totally new project. That one does work now without the issue.
Thanks all.
‎2024-09-26 4:50 AM
Hello @PRODNAV and welcome to the community,
No sure I understood the case.
@PRODNAV wrote:
There is only one thing wrong: The ID has bit1 that keeps being set to 1. So if i would give the adress0x200 (0b0010 0000 0000) it outputs 0b0110 0000 0000)
How did you test this behavior? Could you please elaborate? maybe share screenshots?
Thank you.
‎2024-09-26 6:53 AM
As you can see, Bit 1 is high for the ID. But i have programmed 0x180 for the 11bit ID, but somehow it sets the Bit1 high
‎2024-09-27 12:32 AM
Do you have a communication issue? are you receiving bad ID messages in loopback mode?
‎2024-09-27 4:57 AM
The communication is all correct in external loopback mode. Only the can id is incorrect on one bit (bit1). No matter what id i chose, that bit stays high.
‎2024-09-27 5:26 AM
In that case you need to check your analyzer and its configuration. I don't think there is a an issue with the ID transmission.
‎2024-09-27 5:41 AM
I actually also checked with my oscilloscope. Same bit stays high in the id.
‎2024-09-27 6:03 AM - edited ‎2024-09-27 6:03 AM
Attach a minimal project that reproduces the behavior so we could analyze it later ..
‎2024-09-27 11:47 PM
I have used a small old project that i have to log the ID, and data bytes. This also confirms that Bit1 keeps getting set for the ID.
I attached the code (very basic) that i have made. Can someone please check to see if there is any mistake there?
‎2024-09-30 1:59 AM
Thank you for the sharing.
The attached txt contains a configuration of Normal mode contrarily to what you said in the first post.
For efficiency purposes, please attach a complete minimal working project in Loopback mode that you used to reproduce the behavior.
Thank you.
