2020-05-05 4:33 AM
Hi, This particular MCU is not fully populate in project generator, the result when trying to create a project is incomplete project that can't compile. I worked-around by selecting a different MCU, but as migrating between MCU is not supported, I am facing a wall, and I don't know how to workaround.
Thanks for you attention! Bernard
2020-05-05 6:09 AM
Hello @BVauc.1 ,
Please share your ioc file to check your project, maybe it is not set up properly.
What do you mean migrating between MCU is not supported ? Did you search and select "List Pinout Compatible MCUs" from the Pinout menu ?
Best Regards,
Imen
2020-05-05 9:49 AM
Hello, thanks for checking, it was an automatic update just now that seems to solve the issue, if you are at this initiative, thank you, it works now.
2020-05-05 9:58 AM
What I mean by migrating: once a project is created in CubeIDE, there is no possible to replace the MCU type by another type. Is it correct?
