Adding a file (Inc)
chriskuku
Senior II
Somehow I'm blinded at the moment. How do I simply add a file from the filesystem into the project ?
I created a header file "times.h", put it into ~/STM32CubeIDE/workspace_1.4.0/project/Core/Inc. Now it sits there. Opening the tree view, I don't see it. Clicking "New" I don't see an option to import a file. Only create new ones.
Ah, now, I tried "Refresh" and it's there. Soemhow counterintuitive. But probably this is owed to Eclipse?
Ghofrane GSOURI
Hello @chriskuku
In order to import a file you need to follow those steps:
- Click on File -->Import
- Under General , select File System  then next
- Choose the directory where the file exist and then select the file and finally click on finish
Thx
Ghofrane
3 REPLIES 3
Ghofrane GSOURI
Hello @chriskuku
Thx
Ghofrane
Pavel A.
Evangelist III
Yes, Eclipse. Live and learn ))
chriskuku
Senior II
Thanks for the detailed tour. Yes, import from file system is the solution. I forgot.
