2023-03-20 02:57 AM
Every time I try to import a project to VSCode I get the following vcpkg configuration error:
read_contents("C:\Users\<username>\AppData\Roaming\Code\User\globalStorage\ms-vscode.vscode-embedded-tools\vcpkg\root\scripts\vcpkgTools.xml"): no such file or directory
Do you know where I'm supposed to get vcpkgTools.xml from ? Is that a file that should get installed through the extension?
2023-03-28 11:06 PM
Powershell version is 5.1
2023-08-01 02:24 AM
I also got this error and solved it as fololows:
