2024-07-11 1:35 PM
Running the 2.0.0 version, in any build task, I get jumbled output as if multiple processes are printing to the same terminal. I've looked through tasks.json and launch.json and can't find an argument that fixes this. I assume the plugin needs to be updated. Is there a place to submit a PR or is there another way to fix this?
2024-07-17 1:18 AM
Hi @SpencerG
seems that you have another extension trying to log in the output window at the same time.
Could you check please which extension is logging the red message please ?
