No boot after flashing the STM32MP157f-dk2 SD card
‎2024-12-13 03:05 PM
Hi all,
I just got the board and off course now want to follow the official page (https://wiki.stmicroelectronics.cn/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP135x-DK/Let%27s_start/Populate_the_target_and_boot_the_image) for flashing.
OS windows 10.
STMCubeProgrammer v2.18.0
- inserted SD card to board, SW1 set to USB, connected PC with CN7
- started the STMCubeProgrammer and successfully connected to USB1 (so drivers OK)
- downloaded en.FLASH-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v24.11.06.tar.gz and unpacked
- run in cmd: C:\Program Files(x86)\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=usb1 -w C:\<path>\FlashLayout_sdcard_stm32mp157f-dk2-optee.tsv
- see result Download.png (as I never saw a correct log I think here something went wrong after "Reconnecting the device ...")
- on display: "DFU alt info setting: done"
"crq->brequest: 0x0" - power off, SW1 set to SD card (position oppostite from USB), power ON
- nothing on display and on uart
- Labels:
STM32MP15 Lines
‎2024-12-16 05:39 AM
this is two common pitfalls which could make this to happen:
- Supply is detected as non-compliant with Type-C power supply. Red led bright and there is message on the board console log (STLINK USB Virtual Com Port).
- When using Linux over a Virtual Machine, when downloaded uBoot starts, the USB port newly enumerated should be defined to connect automatically to the virtual machine (as usually by default connected to Windows OS).
Regards,
‎2024-12-16 10:00 AM
Hi PatrickF,
I use official Raspi 4 (ouput 5.1V 3A 15.3W) charger which should be ok for the board.
I use windows 10 pure and no VM or wsl2. I dont see any error anywhere.
I suspect 3 things.
- Something wrong with usb port on board but than it partially downloaded as seen on the picture I attached.
- I suspect some bug in the Cube programmer as it basically crashes after message "reconnecting devices"
- some problem with the usb on my laptop (but I doubt this)
I flashed so far the booloader with balenaEtcher to the SDCard and this is ok I reach the u-boot.
I also did this https://bootlin.com/blog/building-a-linux-system-for-the-stm32mp1-basic-system/ and works perfectly.
So my problem is CubeProgrammer is not transferring files to the SDCard. Strange thing is why the programmer crashes and not displaying some error code? Should I try some older versions and/or install a VM and flash it from linux?
Regards,
Andor
‎2024-12-16 11:43 PM
Power supply could be 5V 3A and NOT USB Type-C compliant (there is many on the market). RPi does not check this compliance as our OpenSTLinux Starter Package do (it could be disabled when you will rebuild a now image for this board or a custom board).
Could you share the board console log by connecting STLINK connector to a PC and running a terminal emulator on the related Virtual Com Port?
Btw, the link you provided in your first post is not for the right product/board (but should not make difference as in the screen capture, I see right files)
Regards.
‎2024-12-17 12:24 AM
Hi PatrickF,
Here is the DFU_log.txt, thx for looking into it.
I am still wondering why the programmer closes itself and not to pop up some error? This can also be a a combination of bug in the programmer and error on the board which crashes the tool.
Regards.
‎2024-12-17 12:49 AM
also attaching 2 pictures to see the LEDs, during download and after the Cubeprogrammer closes (crashes)
‎2024-12-17 12:58 AM
ok, so maybe a missing USB driver on the PC (I guess during CubeProg install).
Could you look at Windows Device Manager (after the 'reconnect') to see if 'reconnected' DFU is present.like this
Regards,
‎2024-12-17 03:08 AM
hm yes it doesn't look that fancy
but I ran from shell STM32Bootloader.bat I even commented the @Echo off to check which if else enters the bash script
‎2024-12-19 12:53 AM
Hi PatricF,
I tried to reinstall all again but no luck.
I debugged the STM32Bootloader.bat and from if else it enters the:
start "STM32 USB DFU DRIVER" pnputil -i -a %0\..\Driver\STM32Bootloader.inf
but the log I get:
pnputil -i -a "c:\Program Files (x86)\STMicroelectronics\STM32Cube\STM32CubeProgrammer\Drivers\DFU_Driver\Driver\STM32Bootloader.inf"
Microsoft PnP Utility
Processing inf : STM32Bootloader.inf
Failed to install the driver : No more data is available.
Total attempted: 1
Number successfully imported: 0
regards
‎2024-12-19 02:07 AM
Hi @anpa
strange as CubeProgramer should have been installed in C:\Program Files and not c:\Program Files (x86)
What result did you get if you right click on STM32Bootloader.inf file then select install ?
Regards.
