Is there a way to load more than one file at a time in automatic mode using STM32CubeProgrammer?
kwhit.1
I want to load a bootloader and then the firmware to my board via ST Link in one pass in an automatic mode.
Kevin HUBER
Hello @kwhit.1​ ,
What is the board that you are using?
Flashing several binaries is supported by default with the tsv file that you provide to Cubeprogrammer.
Please have a look to the wiki: https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer#Flash_programming_principles
Best Regards,
Kevin
Kevin HUBER
Hello @kwhit.1​ ,
Best Regards,
Kevin
Thank you,
Sorry to waste your time. I asked the question without reading the details.
