Where do I find BootROM traces error codes ?
‎2022-05-04 6:11 AM
I am debugging a STM32MP1 boot but the bootrom does not manage to boot the FSBL from the SDMMC interface.
I extracted the traces and ran the bootrom trace analyzer script. However, some of the error messages contain error codes for which I could not find an explanation.
The relevant lines are:
< @ 00981105 | [ERR ] - SD_OverallRetryCnt ( 0x00000003 ) >
< @ 00981491 | [ERR ] - SD_InitDetailedErrorDesc ( 0x00000029 ) >
< @ 00981907 | [ERR ] - SD_InitFailed >
What do the hexadecimal codes mean (the 0x00000003 and 0x00000029)?
In case it is needed, the full output from the script is attached.
Thank you for your help
- Labels:
STM32MP15 Lines
‎2022-05-04 7:11 AM
HI @bfh_dls​
value in parenthesis are not always error codes, but rather various parameters for more deep analysis by our internal team if needed.
For instance, here "( 0x00000003 )" shows that 3 retries has been done.
or later "BOOTCORE_HseFrequencyDetected ( 0x00000018 ) " reflect that 24MHz (0x18=24 decimal) has been detected on HSE.
On my side, I have not enough information for the "( 0x00000029 )" meaning.
But as the Bootrom.log file you share is exactly the same I got on one of our board (e.g. STM32MP157F-DK2) with no SD-Card connected. I suspect a more basic issue.
Please check:
- SD-Card pinout on your custom board (beware of non standard numbering on some SD-Card sockets)
- presence of 3.3V SD-Card supply
- CLK presence on pin PC12 during boot (will likely stop after few tens of ms if error is detected)
- some CMD activity on pin PD2. Inactive level should be 'high'
- D0 (usually card response) on pin PC8. Inactive level should be 'high'
Btw, did you use level translator between STM32MP15x and SD-Card (e.g. to support UHS-I) or a simple and direct connection ?
If you still have issue, maybe worth to share your schematics.
Regards.
‎2022-05-04 8:23 AM
Thank you for your answer.
I confirmed that I get the same bootrom trace when using a demo board without SD card.
I don't have a level translator on my lines but an EMI filter (EMIF06-MSD02N16).
‎2022-05-04 8:58 AM
Did you have a look to SD-Card signals as I proposed above ?
If no clock, there is likely an Hw issue as BootROM log show that the SD-Card trial is correctly done.
- mixed-up SOM pinout or PCB library
- mixed-up SD-Card pinout or PCB library
- mixed-up EMI filter pinout or PCB library
- etc...
Looking at your schematics does not give much information to me.
As you use a SOM from a 3rd party (assuming this is a working module), you could double check your SOM pinout/schematics Vs the official baseboard documentation provided by the SOM maker.
Maybe worth to contact the SOM maker.
Regards.
‎2022-05-05 5:49 AM
I may have found an issue on your schematics.
There is two different supply names: +3.3V and +3V3.
Please confirm both are connected together.
Regards.
‎2022-05-09 5:24 AM
Hi Patrick,
The +3.3V and +3V3 are indeed connected together, the naming will be fixed in the schematic to avoid confusion though.
I did test the SD card interface with an oscilloscope and did not get a signal. I will check the PCB in detail.
I will also try the SDcard interface without EMI protection to make sure it does not interfere with communication.
Regards,
