STM32MP157 ADC failing to probe during boot
LinuxAddict
Greeting.
I'm trying to get our ADC subsystem up and running and getting weird errors in dmesg during boot. I'm assuming I've done something wrong with devicetree but I can't seem to figure out a working combination from the docs.
Full part number of our MPU is STM32MP157CAC3.
During boot we get error -61 during the probe of the two converters as shown below
Thanks,
-LinuxAddict
$ dmesg | grep -E "adc|iio"
[ 2.510869] iio iio:device0: No channels configured
[ 2.514812] stm32-adc: probe of 48003000.adc:adc@0 failed with error -61
[ 2.522467] iio iio:device0: No channels configured
[ 2.526055] stm32-adc: probe of 48003000.adc:adc@100 failed with error -61
Here's our devicetree portions:
&pinctrl {
    adc1_pins: adc1-single-ended {
        analog-inputs1 {
            pinmux = <STM32_PINMUX('C', 0, ANALOG)>,
                     <STM32_PINMUX('A', 5, ANALOG)>;
            bias-disable;
&adc {
    pinctrl-names = "default";
    pinctrl-0 = <&adc1_pins>;
    status = "okay";
    vdda-supply = <&vdd>;
    vref-supply = <&v3v3>;
    /* ANALOG_IN1 = ADC2_INP0 (pin ANA0) */
    /* ANALOG_IN2 = ADC2_INP1 (pin ANA1) */
    /* ANALOG_IN3 = ADC1_INP10 (pin PC0) */
    /* ANALOG_IN4 = ADC1_INP19 (pin PA5) */
    adc1: adc@0 {
        status = "okay";
        channel@0 {
            reg = <0>;
            st,min-sample-time-ns = <10000>;  /* 10µs sampling time */
            label = "ANALOG_IN_1";
        channel@1 {
            reg = <1>;
            label = "ANALOG_IN_2";
    adc2: adc@100 {
        status = "okay";
        channel@10 {
            reg = <10>;
            label = "ANALOG_IN_3";
        channel@19 {
            reg = <19>;
            label = "ANALOG_IN_4";
LinuxAddict
In case anyone else runs into these issues, I didn't understand that functioning ADC/IIO driver is silent in the kernel logs. It was actually working the whole time.
4 REPLIES 4
Gregory PLANCHON
Hi @LinuxAddict ,
Have you checked the various wiki pages to see if you've missed anything?
https://wiki.st.com/stm32mpu/wiki/ADC_device_tree_configuration
https://wiki.st.com/stm32mpu/wiki/ADC_OpenSTLinux_drivers
Grégory
Gregory,
Yes, thank you for the response.
I've consulted both of the wiki pages paying especially careful attention to the ADC device tree page to no avail.
Thanks,
-Adrian
Hi @LinuxAddict ,
Could you check these different points, please:
  • Are you sure about the pinctrl you indicated?
  • Are you sure your power supply is correct and properly configured?
  • Are you sure you're on the right channels?
Grégory
LinuxAddict
