STM32CubeIDE on Windows 7
techdesk
Hello
I tried everything but I cannot get STM32CubeIDE to get the editor to work.
I just keep on getting this message: There is no active editor that provides an outline.
I spent hours re-installing but nothing worked
All help will be appreciated
13 REPLIES 13
Maybe try old version - afair i had  CubeIDE v1.10.0  installed on Win7 .
main.c   MouseClick  returns "no active editor that provides an outline"
Environment: Windows 11. date 11jan2025
  Go to windows explorer:
     DoubleClick  any *.c file.  ( or find your actual .. project... main.c  file)
        WINDOWS ASKS YOU TO "SELECT AN APP TO EDIT THIS main.c FILE
          Select NotePad
      Close everything
 Restart
If you have made an IDE-project, it should look like this :
"no active editor that provides an outline" = something is missing, to let the IDE know, what to do.
Is this your first try with this IDE ?  -> read the manual, ...first : get started etc.
https://wiki.st.com/stm32mcu/wiki/Category:STM32CubeIDE
https://www.st.com/resource/en/user_manual/um2553-stm32cubeide-quick-start-guide-stmicroelectronics.pdf
https://www.st.com/resource/en/user_manual/um2609-stm32cubeide-user-guide-stmicroelectronics.pdf
This was my SOLUTION to the issue discussed. It was NOT a problem description. Sorry for any misunderstanding!
