No package 'wayland-client-protocol' found !
‎2022-04-12 8:06 AM
Hello ,
I am building one application using Open gl es code. but gettign this error.Not sure if it is error as the final applications is building fine but giving error while elaunching .
Finished building target: my application
on launching this application it gives :
========== init_wayland_system ==========
Error : No such file or directory
can't connect to wayland display
WHats happening here?
D
STM32MP15 Lines
‎2022-04-14 7:46 AM
Hello @darla14​ ,
Could you please give me a little bit more information concerning your issue ?
- Are you using Distribution or Developer package to make your application ? (If Distribution, with which OpenSTLinux version ?)
- Is it possible to share us your source code to replicate from our side ?
Regards.
Erwan.
‎2022-04-18 9:48 PM
Hello @Erwan SZYMANSKI​ ,
thanks for the reply,
I cross-compiled the application using the mpu toolchain ( in sdk) for the starter package I flashed,. It has some code that runs on the gpu.
Difficult to share sc ...but i will check..
what issue do you see?
Br,
‎2022-04-22 3:10 AM
Hello @darla14​ ,
sorry for late answer, are you still blocked ?
Ok no problem for the SC, can you share me your Makefile or your compilation options (CCFLAGS, LDFLAGS etc..) with masking sensitive information if there are ?
Rgs.
Erwan.
‎2022-04-22 5:41 AM
Moreover, do you have a weston service running when you try to execute your command ?
As far as I remember, using OpenGL ES with wayland-egl library needs it.
Regards.
Erwan.
‎2022-04-22 10:16 AM
Thanks @Erwan SZYMANSKI​
Let me check on all these points and come back !
Br,
‎2022-06-09 5:11 AM
Hello @darla14​ ,
Do you still need help on this issue?
Kevin
‎2022-06-09 11:15 AM
Not now,thanks for the comment . @Kevin HUBER​
