image download to sdcard with STM32MP157D-EV1
HKim.23
Uploaded Image to SDCARD using VMWARE. However, it does not boot normally.
Below is the log when downloading. lastly, "unable to reconnect" error occurs.
------------------------------------------- log start -------------------------------------
denniskim@denniskim-pc:~/STM32MPU_workspace/STM32MP15-Ecosystem-v3.0.0/Starter-Package/stm32mp1-openstlinux-5.10-dunfell-mp1-21-03-31/images/stm32mp1$ STM32_Programmer_CLI -l usb
      STM32CubeProgrammer v2.7.0
===== DFU Interface =====
Total number of available STM32 device in DFU mode: 1
 Device Index   : USB1
 USB Bus Number   : 001
 USB Address Number  : 002
 Product ID    : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
 Serial number   : 002500473438511836383238
 Firmware version  : 0x0110
 Device ID    : 0x0500
denniskim@denniskim-pc:~/STM32MPU_workspace/STM32MP15-Ecosystem-v3.0.0/Starter-Package/stm32mp1-openstlinux-5.10-dunfell-mp1-21-03-31/images/stm32mp1$ STM32_Programmer_CLI -c port=usb1 -tm 40000 -w flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157d-ev1-trusted.tsv
Warning: Timeout is forced to 40000 ms
USB speed : Full Speed (12MBit/s)
Manuf. ID : STMicroelectronics
SN   : 002500473438511836383238
FW version : 0x0110
Device ID : 0x0500
Device name : STM32MP1
Device type : MPU
Device CPU : Cortex-A7
Start Embedded Flashing service
Memory Programming ...
Opening and parsing file: tf-a-stm32mp157d-ev1-usb.stm32
 File   : tf-a-stm32mp157d-ev1-usb.stm32
 Partition ID : 0x01
Download in Progress:
[==================================================] 100%
File download complete
Time elapsed during download operation: 00:00:04.660
RUNNING Program ...
 PartID:  :0x01
Start operation done successfully at partition 0x01
Flashlayout Programming ...
Running Flashlayout Partition ...
Flashlayout partition started successfully
Opening and parsing file: fip-stm32mp157d-ev1-trusted.bin
 File   : fip-stm32mp157d-ev1-trusted.bin
 Partition ID : 0x03
Time elapsed during download operation: 00:00:28.677
RUNNING Program ...
 PartID:  :0x03
Reconnecting the device ...
Error:
Unable to reconnect the target device: time out expired
Error: Start operation failed at partition 0x03
Error: TSV flashing service failed
---------------------------------------------log end-------------------------------------------------------
I found an answer to the same issue.
I tried using windows' stm32cubeprogrammer as a solution to another question.
However, when the download button is pressed, the following error occurs.
 16:54:02 : Error: The file tf-a-stm32mp157d-ev1-usb.stm32 does not exist, please check the file's path
 16:54:02 : Error: Download partition 0x01 failed
 16:54:02 : Error: TSV flashing service failed
OlivierK
Hello HKim.23 (Community Member)
1- As you are using VMWare and Windows on the same machine, could you make sure the USB ressources are not shared between the 2 OS while using STM32CubeProgrammer.
2- I've just checked the source files of the starter package,  tf-a-stm32mp157d-ev1-usb.stm32 is indeed present. Make sure you select the right path in the "Binary Path" and double check the file is present (or download again the starter package https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32-mpu-openstlinux-distribution/stm32mp1starter.html
Best Regards,
Olivier
6 REPLIES 6
OlivierK
Best Regards,
Olivier
OlivierK, Thanks a lot.
Once I succeeded in downloading through Windows.
In order to successfully download in Windows, the bin folder containing STM32_Programmer_CLI is registered as the environment variable PATH.
Then I went to the folder where the Image is and performed the download.
Downloaded normally.
But I still have questions. If you know about this, please reply.
1. When downloading in Windows, the download speed is very slow. Do you have any way to improve this? Now it takes over a minute.
2. If using Vmware, you said "make sure the USB ressources are not shared". Is this possible in Vmware? If you know how to set this up, please guide me.
for reference, to use usb in Vmware linux, I am using as follows.0693W00000D04DHQAZ.png
OlivierK
Hi HKim.23 (Community Member)
  1. Regarding the download speed, what do you mean by very slow? I would select USB 3.0 (instead of USB 2.0) as you shared in the above picture. Apart from this there's nothing much you can do to improve the download speed. Did you try the same using STM32CubeProgrammer on Linux side using VMWare?
  2. I see Oracle Virtual box in the above picture, which is rather different than VMWare. On VMWare Workstation 16 player, once you plug a USB device, a popup window ask whether to allocate the ressource to VMWare or to the Host, there's also a tick box at the bottom to memorize the ressource allocation.
OlivierK
HKim.23
I confused VMWare and VirtualBox.
I will try what you said.
Thank you for answer.
OlivierK
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
