How to flash TF-A , u-boot , root file system to SD card without USB with STM32CubeProgrammer
HMasu.1
Following Wiki page shows how to flash TF-A , u-boot , root file system to SD card with STM32CubeProgrammer.
https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer#How_to_flash_with_STM32CubeProgrammer
In the above wiki page, I can flash ​TF-A , u-boot , root file system to SD card using USB.
Now, I want to flash ​images to SD card without using USB (directly from Host Linux PC).
Is there any way to ​flash ​TF-A , u-boot , root file system to SD card without using USB with STM32CubeProgrammer?
Best Regards.
H. Masuda
Fee
Fee
If 'I understand you correctly this should help you: https://wiki.st.com/stm32mpu/wiki/How_to_populate_the_SD_card_with_dd_command
HMasu.1
Hi, @Lukas Brückner​
Thank you for your prompt reply.
Following Steps in Wiki Page you taught, I was able to flash ​images to SD card directly from Host Linux PC.
I am very grateful for your help.
H. Masuda
