Error: failed to download Segment[0]
‎2019-08-29 7:19 AM
Hallo,
Im trying to flash an image (st-example-image-qt-openstlinux-eglfs-stm32mp1), bu it fails on partition 0x23
this is the output on Terminal:
giomate@giolaptop:~/Development/STM32/MP15/Distribution/openstlinux/build-openstlinuxeglfs-stm32mp1/tmp-glibc/deploy/images/stm32mp2/stm32mp1$ STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-example-image-qt/FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv -log
STM32CubeProgrammer v2.1.0
Log output file: /home/giomate/.STM32CubeProgrammer/trace.log
USB speed : High Speed (480MBit/s)
Manuf. ID : STMicroelectronics
Product ID : USB download gadget@Device ID /0x500, @Revision ID /0x0000
SN : 0030002C3338510939303435
FW version : 0x0110
Device ID : 0x0500
Device name : STM32MPxxx
Device type : MPU
Device CPU : Cortex-A7
Start Embedded Flashing service
Memory Programming ...
Opening and parsing file: st-example-image-qt-openstlinux-eglfs-stm32mp1.ext4
File : st-example-image-qt-openstlinux-eglfs-stm32mp1.ext4
Partition ID : 0x23
Download in Progress:
[=================================== ] 70%
Error: failed to download the File
Time elapsed during download operation: 00:14:00.737
Error: Download partition 0x23 failed
Error: TSV flashing service failed
I appeciate any comment or suggestions
- Labels:
STM32MP15 Lines
‎2019-08-31 7:10 AM
Yeap, it was the sizes of the roofs partition
‎2019-08-29 11:35 PM
Probably linked to that issue (assigned size/offset in Flashlayout too small for your image) https://community.st.com/s/question/0D50X0000B7Ykl5SQC/getting-failure-while-compiling-qtwebkit-for-yocto
‎2019-08-31 7:10 AM
‎2025-03-26 10:48 PM
STMicroelectronics ST-LINK GDB server. Version 7.8.0
Copyright (c) 2024, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
InitWhile : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connected
STM32CubeProgrammer v2.17.0
Log output file: C:\Users\rlv\AppData\Local\Temp\STM32CubeProgrammer_a26804.log
ST-LINK SN : "
ST-LINK FW : V2J45S7
Board : --
Voltage : 3.30V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x461
Revision ID : Rev 2.0
Device name : STM32L496xx/STM32L4A6xx
Flash size : 512 KBytes
Device type : MCU
Device CPU : Cortex-M4
BL Version : 0x93
Debug in Low Power mode enabled
Opening and parsing file: ST-LINK_GDB_server_a26804.srec
File : ST-LINK_GDB_server_a26804.srec
Address : 0x08000000
Erasing internal memory sectors [0 277]
Encountered Error when opening C:\ST\STM32CubeIDE_1.14.1\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.1.400.202404281720\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Shutting down...
Exit.
Step 1: Full chip erase
