SPI Configuration issue
RBorr.1
I am working on a project where the hardware platform is based on STM32MP157c and the OS is Linux 4.19.9 .
I am facing on a issue about device tree spi configuration.
Following SPI_overview on wiki.st.com kernel config has been modified with:
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_STM32=y
CONFIG_SPI_SPIDEV=y
while dts file has been modified adding spi2 DT configuration:
&spi2{
   pinctrl-names = "default", "sleep";
   pinctrl-0 = <&spi2_pins_mx>;
   pinctrl-1 = <&spi2_sleep_pins_mx>;
       cs-gpios = <&gpioi 0 0>;
   status = "okay";
   /* USER CODE BEGIN spi2 */
       spidev@0x00 {
               compatible = "spidev";
               #address-cells = <1>;
               #size-cells = <0>;
               reg = <0>; /* CS #0 */
               spi-max-frequency = <10000000>;
   /* USER CODE END spi2 */
When the system goes up on /dev "spi" is not present and the dmesg reports the following error:
[ 1.782858] spi_stm32 4000b000.spi: clk rate = 0
[ 1.786353] spi_stm32: probe of 4000b000.spi failed with error -22
Attached config and dts files
Kind Regards
Renato
PatrickF
did you configure the SPI kernel clock source in RCC ?
You could try to build a dummy project using CubeMx and retrofit the right portions in your Device Tree files (likely TF-A ones)
Regards.
RBorr.1
Hi Patrick,
after the changes on RCC on TF-A dbs file, as suggested, the spi is now available.
Thanks a lot
Best Regards
Renato
I was trying to solve the same issue as the author described during the whole last week
I remember having checked RCC configuration and SPI (spi5 I use) was configured as it should. However after reading your post I checked again, and found something weird on my tf-a dts file: even though it had a first definition of RCC with spi5 configured, at the end of my file in section "user code addons" there was a redefinition of RCC config with spi5 not configured. I removed this redefinition and the issue resolved. I don't understand why CubeMX put it there but removing it fixed my problem.
I uploaded this dts file so you may see it yourself, because I think this may be a CubeMX bug.
