Migrating From Dunfell to Kirkstone LCD over SPI using FBTFT no longer working
iheb
Hello ST Dear ST Community,
I'm currently trying to migrate my solution from stm32mp1-openstlinux-5-4-dunfell-mp1-20-06-24   to stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15
Im using a ST7789V Based LCD, and its working trough /dev/fb0 and fbdev under /video/
fbtft and /video/fbdev under dunfell sources
however in the kirkstone distro stuff are different , i only see staging/fbtft , i managed to get the right configuration and activate it the LCD driver is loaded
in the boot it shows this
[    0.516659] SPI driver fb_st7789v has no spi_device_id for sitronix,st7789v
[    9.137538] systemd[1]: System time before build time, advancing clock.
[    9.248500] ipv6: module verification failed: signature and/or required key missing - tainting kernel
[    9.274214] NET: Registered PF_INET6 protocol family
[    9.314553] Segment Routing with IPv6
[    9.316896] In-situ OAM (IOAM) with IPv6
[    9.383063] systemd[1]: systemd 250.4-1-gc3aead5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK -SECCOMP -GCRYPT -GNUTLS -OPENSSL -ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    9.414966] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - EGLfs - (A Yocto Project Based Distro) 4.0.1-snapshot-20240509 (kirkstone)!
[    9.510758] systemd[1]: Using hardware watchdog 'STM32 Independent Watchdog', version 0, device /dev/watchdog0
[    9.529233] systemd[1]: Watchdog running with a timeout of 32s.
[   12.664201] systemd[1]: /lib/systemd/system/mount-partitions.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   12.705179] systemd[1]: Queued start job for default target Multi-User System.
[   12.776605] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[   12.813304] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[   12.853314] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[   12.892602] systemd[1]: Created slice User and Session Slice.
[   22.656775] fb_st7789v spi1.0: fbtft_property_value: width = 240
[   22.705586] dwc2 49000000.usb-otg: bound driver configfs-gadget
[   22.763362] fb_st7789v spi1.0: fbtft_property_value: height = 320
[   22.768061] fb_st7789v spi1.0: fbtft_property_value: buswidth = 8
[   22.875216] fb_st7789v spi1.0: fbtft_property_value: backlight = 55
[   22.916872] fb_st7789v spi1.0: fbtft_property_value: rotate = 0
[   22.962507] fb_st7789v spi1.0: fbtft_property_value: fps = 30
[   22.968499]  init panda
[   23.069856] dwc2 49000000.usb-otg: new device is high-speed
[   23.149675] dwc2 49000000.usb-otg: new device is high-speed
[   23.218440] dwc2 49000000.usb-otg: new address 46
[   23.241096] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[   23.934567] graphics fb0: fb_st7789v frame buffer, 240x320, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi1.0 at 10 MHz
[*     ] A start job is running for Wait for…ice Initialization (11s / 3min 7s)
[   24.473763] stm32-adc 48003000.adc:adc@100: No channel found
[   24.478101] stm32-adc: probe of 48003000.adc:adc@100 f
[**    ] A start job is running for Wait for…ice Initiali
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Created slice Slice /system/systemd-backlight.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting Load/Save Screen …f backlight:panel-backlight...
[  OK  ] Finished Load/Save Screen … of backlight:panel-backlight.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ]
My configuration file
# General setup
CONFIG_POSIX_MQUEUE=y
CONFIG_USELIB=y
CONFIG_FUTEX=y
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
# RCU Subsystem
# allow user to access kernel config through /proc/config.gz
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=16
CONFIG_MEMCG=y
CONFIG_NAMESPACES=y
# Kernel Performance Events And Counters
CONFIG_PROFILING=y
# Kernel Features
CONFIG_SCHED_MC=y
CONFIG_MCPM=y
CONFIG_NR_CPUS=2
CONFIG_AEABI=y
CONFIG_HIGHMEM=y
CONFIG_FORCE_MAX_ZONEORDER=12
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
# CPU Power Management
# Floating point emulation
CONFIG_VFP=y
# Networking options
CONFIG_DNS_RESOLVER=y
# CAN Device Drivers
CONFIG_CAN_M_CAN=y
CONFIG_CAN_M_CAN_PLATFORM=y
# CAN USB interfaces
# Bluetooth device drivers
# Device Drivers
# Generic Driver Options
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
# Disk-On-Chip Device Drivers
# LPDDR & LPDDR2 PCM memory drivers
# Misc devices
CONFIG_SRAM=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_CHR_DEV_SG=y
# MII PHY device drivers
# Input Device Drivers
# Touchscreen drivers
CONFIG_TOUCHSCREEN_EDT_FT5X06=y
CONFIG_TOUCHSCREEN_GOODIX=y
# Character devices
CONFIG_LEGACY_PTY_COUNT=8
# Non-8250 serial port support
CONFIG_SERIAL_NONSTANDARD=y
# SPI Master Controller Drivers
# Pin controllers
CONFIG_PINCTRL_MCP23S08=n
# Memory mapped GPIO drivers
# Memory Technology Device (MTD) support
CONFIG_MTD_SPI_NAND=y
CONFIG_MTD_MCHP23K256=m
# Multiple devices driver support
CONFIG_MD=y
#Device mapper support
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
# USB GPIO expanders
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_SYSCON=y
# Native drivers
CONFIG_SENSORS_IIO_HWMON=y
CONFIG_THERMAL=y
# STMicroelectronics thermal drivers
# Watchdog Device Drivers
CONFIG_WATCHDOG_NOWAYOUT=y
CONFIG_WATCHDOG_SYSFS=y
# Sonics Silicon Backplane
# Multifunction device drivers
CONFIG_PROTECTION_CONSUMER=y
# Multimedia core support
# USB HDMI CEC adapters
CONFIG_CEC_STM32=m
# Camera sensor devices
CONFIG_VIDEO_GC2145=m
CONFIG_VIDEO_OV5640=m
CONFIG_VIDEO_ST_MIPID02=m
# Graphics support
# to solve issue on DK2 screen
# CONFIG_DRM_FBDEV_EMULATION is not set
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# Sub-drivers
# Display Panels
CONFIG_DRM_PANEL_ORISETECH_OTM8009A=n
CONFIG_DRM_PANEL_RAYDIUM_RM68200=n
CONFIG_DRM_PANEL_ROCKTECH_HX8394=n
# Display Interface Bridges
#CONFIG_DRM_I2C_ADV7511=y
#CONFIG_DRM_SII902X=y
# Frame buffer hardware drivers   <===========
CONFIG_DRM_SIMPLEDRM=n
# Console display driver support
CONFIG_DRM_STM=y
CONFIG_DRM_STM_DSI=y
# Backlight support
CONFIG_BACKLIGHT_GPIO=y
# HD-Audio
# STMicroelectronics STM32 SOC audio support
CONFIG_SND_SOC_STM32_SPDIFRX=m
CONFIG_SND_SOC_STM32_DFSDM=m
# CODEC drivers
# USB Device Class drivers
CONFIG_USB_ACM=m
# also be needed; see USB_STORAGE Help for more info
# Gadget/Dual-role mode requires USB Gadget support to be enabled
# USB Physical Layer drivers
# USB UCSI with STM32G07 over I2C
CONFIG_TYPEC_UCSI=m
CONFIG_UCSI_STM32G0=m
# Platform Support
# Virtio drivers
# STM32 HSEM
CONFIG_HWSPINLOCK=y
CONFIG_HWSPINLOCK_STM32=y
# Clock Source drivers
CONFIG_CLKSRC_STM32_LP=y
# Regulators
CONFIG_REGULATOR_STM32_VREFBUF=y
# Remoteproc drivers
CONFIG_REMOTEPROC=y
CONFIG_STM32_RPROC=y
CONFIG_REMOTEPROC_SRM_CORE=y
CONFIG_REMOTEPROC_SRM_DEV=y
# Rpmsg drivers
CONFIG_RPMSG_VIRTIO=y
CONFIG_RPMSG_TTY=m
# NVMEM drivers
CONFIG_NVMEM_STM32_ROMEM=y
CONFIG_TEE=y
# TEE drivers
CONFIG_OPTEE=y
# end of TEE drivers
# File systems
CONFIG_OVERLAY_FS=y
CONFIG_JFFS2_FS=y
# Pseudo filesystems
CONFIG_TMPFS=y
# Security options
CONFIG_KEYS=y
# Library routines
CONFIG_CRC_ITU_T=m
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=128
# Kernel hacking
# printk and dmesg options
CONFIG_DYNAMIC_DEBUG=y
# Compile-time checks and compiler options
CONFIG_DEBUG_INFO=y
CONFIG_GDB_SCRIPTS=y
CONFIG_DEBUG_SECTION_MISMATCH=y
# Debug Oops, Lockups and Hangs
# Scheduler Debugging
CONFIG_DEBUG_PREEMPT=y
# Runtime Testing
# STM32 DFSDM
CONFIG_SD_ADC_MODULATOR=y
# STM32 IPCC
CONFIG_STM32_IPCC=y
# SCMI
CONFIG_ARM_SCMI_PROTOCOL=y
CONFIG_COMMON_CLK_SCMI=y
CONFIG_ARM_SMC_MBOX=y
CONFIG_REGULATOR_ARM_SCMI=y
CONFIG_ARM_SCMI_CPUFREQ=y
# STM32 CPUIDLE
CONFIG_CPU_IDLE=y
CONFIG_ARM_STM32_CPUIDLE=y
CONFIG_ARM_CPUIDLE=n
# REBOOT
CONFIG_REBOOT_MODE=y
CONFIG_SYSCON_REBOOT_MODE=y
# RPMSG client sample
CONFIG_SAMPLES=y
CONFIG_SAMPLE_RPMSG_CLIENT=m
# LCD Framebuffer
CONFIG_FB_TFT=y
CONFIG_STAGING=y
#CONFIG_DRM_PANEL_SITRONIX_ST7789V=y
CONFIG_FB_TFT_ST7789V=y
# TTY
# STM32 LPTIMER
CONFIG_MFD_STM32_LPTIMER=y
CONFIG_PWM_STM32_LP=y
CONFIG_IIO_STM32_LPTIMER_TRIGGER=y
CONFIG_STM32_LPTIMER_CNT=y
# STM32 DAC
CONFIG_STM32_DAC=y
my device tree
&spi4 {
	status = "okay";
	pinctrl-0 = <&spi4_pins_mx>;
	pinctrl-1 = <&spi4_sleep_pins_mx>;
	pinctrl-names = "default";
	#address-cells = <1>;
	#size-cells = <0>;
	cs-gpios = <&gpioe 11 GPIO_ACTIVE_HIGH>;
	spidev4: spidev4@0{
	status = "disabled";
 	display: display@0{
		compatible = "sitronix,st7789v";
		reg = <0>;
		buswidth = <8>;
		custom = <1>;
		bgr;
		spi-3wire = <0x01>;
		fps = <30>;
		rotate = <0>;
        	width = <240>;
        	height = <320>;
		spi-max-frequency = <20000000>;
		dc-gpios = <&gpiof 0 GPIO_ACTIVE_HIGH>;
		reset-gpios = <&gpioc 2 GPIO_ACTIVE_HIGH>;
		backlight = <&panel_backlight>;
		port@0{
			panel_input: endpoint {
			remote-endpoint = <&ltdc_ep1_out>;
Also when probing the SPI outputs , the device seems to generate control signals when using the command fb-test
I appreciate any help, I'm open to other methods as long as it gets the LCD working again
Thank you
iheb
Update i was able to get it working. i just replaced all the FBTFT from the previous version to the newer version..
there are indeed many updates in how the driver handles the screens.
For example for the ST7789V it now handles and manages the tearing effect in the screens..
iheb
